[fdo-trac] #641: SQLite Can't create a datetime column
FDO trac_fdo at osgeo.org
Fri May 7 12:47:50 EDT 2010
 Reporter:  bscott           |         Owner:  traianstanev
     Type:  enhancement      |        Status:  assigned
 Priority:  blocker          |     Milestone:  3.6.0
Component:  SQLite Provider  |       Version:  3.5.0
 Severity:  1                |    Resolution:
 Keywords:                   |   External_id:
Changes (by romicadascalescu):
  * milestone:  3.5.0 => 3.6.0
Comment:
 Hi Bruno,
 I just dropped a fix in trunk(3.6) which should solve your problems.
 It will not solve all the issues but in case you are using an alias for a
 property you will get the type as it should back.
 Below you can find my change:
 Author: romicadascalescu
 Date: 2010-05-07 12:14:00 -0400 (Fri, 07 May 2010)
 New Revision: 5495
    trunk/Providers/SQLite/Src/Provider/SltReader.cpp
 #504 SQLite provider. Improvements:
 - SQLite: Resolve the property type when caller uses aliases for
 properties
 I hope it helps you.
 Regards,
 Romy.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/641#comment:13>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
