[fdo-trac] #650: Sqlite filter should not be case sensitive
FDO trac_fdo at osgeo.org
Wed May 26 09:56:36 EDT 2010
   Reporter:  bscott         |       Owner:  gregboone
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.6.0
  Component:  FDO API        |     Version:  3.5.0
   Severity:  5 (Wish List)  |    Keywords:
External_id:                 |
 I have a table with all column uppercase
 If i do
   select MYCOLUMN from MYTABLE
      it works fine
   select mycolumn from MYTABLE
      it works fine
   select * from MYTABLE where MYCOLUMN = 1
      it works fine
   select * from MYTABLE where mycolumn = 1
      it does not work
 I have found where the problem is and attached a patch for it
Ticket URL: <http://trac.osgeo.org/fdo/ticket/650>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
