[fdo-trac] #718: XML: Errors at VeryLow level
FDO trac_fdo at osgeo.org
Tue Nov 2 11:32:07 EDT 2010
   Reporter:  brentrobinson  |       Owner:  brentrobinson
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.6.0
  Component:  FDO API        |     Version:  3.6.0
   Severity:  3              |    Keywords:  XML read exceptions error level VeryLow
External_id:                 |
 When a feature schema is read from an XML file, at the VeryLow ErrorLevel
 setting, the following situations result in the read failing with
 exceptions:
  * class definition has a base class that does not exist
  * an association property has a associated class that does not exist.
 The VeryLow error level is intended to do a best effort read so it should
 just skip elements in error and successful read the other elements.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/718>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
