[fdo-trac] #718: XML: Errors at VeryLow level
trac_fdo at osgeo.org
Tue Nov 2 11:37:13 EDT 2010
Reporter: brentrobinson | Owner: brentrobinson
Type: defect | Status: assigned
Priority: major | Milestone: 3.6.0
Component: FDO API | Version: 3.6.0
Severity: 3 | Keywords: XML read exceptions error level VeryLow
External_id: |
Comment(by brentrobinson):
Revision: 5786
Author: brentrobinson
Date: 11:35:48 AM, Tuesday, November 02, 2010
Message:
Ticket#718: Read Xml Schema: When ErrorLevel is VeryLow:
* Skip association properties with non-existent associated classes.
* Skip base class relationships where base class does not exist.
Also fixed problem where descriptions for skipped classes and properties
got assigned to feature schemas.
Modified : /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElement.h
Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchema.cpp
Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp
Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/718#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
