[fdo-trac] #719: Defect in filter parsing
FDO trac_fdo at osgeo.org
Wed Nov 3 12:19:08 EDT 2010
   Reporter:  maland           |       Owner:  gregboone
       Type:  defect           |      Status:  new
   Priority:  major            |   Milestone:  3.6.0
  Component:  ArcSDE Provider  |     Version:  3.5.0
   Severity:  3                |    Keywords:
External_id:                   |
Comment(by romicadascalescu):
 Hi Henning,
 I had a look at you change and it's OK, however I would propose some
 additional changes to remove class FilterAnalyzer and flags
 mFilterAnalyzed, mUseNesting.
 This will simplify the code and will make possible use less brackets in a
 filter. The same method is used in FDO & SQLite filter ToString in order
 to avoid too many brackets.
 Could you please have a loot at the code change proposed and test it if
 possible and let me know your opinion?
 Regards,
 Romy.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/719#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
