[fdo-trac] #548: SQL Spatial 'DataStore' connection property is case sensitive
FDO trac_fdo at osgeo.org
Fri Nov 5 14:45:27 EDT 2010
 Reporter:  chriserickson  |         Owner:  brentrobinson
     Type:  defect         |        Status:  closed
 Priority:  major          |     Milestone:  3.6.0
Component:  FDO API        |       Version:  3.4.0
 Severity:  2              |    Resolution:  fixed
 Keywords:                 |   External_id:
Changes (by brentrobinson):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Revision: 5796
 Author: brentrobinson
 Date: 2:42:24 PM, Friday, November 05, 2010
 Message:
 Ticket#548: Prevent dereferencing null pointer when Schema Manager can't
 locate datastore.
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/Fdo/FdoRdbmsSqlServerConnection.cpp
 Instead of segv, an exception is now thrown indicating that
 the datastore either doesn't exist or was specified in the wrong case.
 A more ambitious fix would be to treat datastore name as case-insensitive
 and allow these types of connection to succeed. However, addressing
 potential side effects for case-sensitive servers could get tricky.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/548#comment:5>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
