[fdo-trac] #721: SQLServerSpatial: cannot access database with all numbers in name
FDO trac_fdo at osgeo.org
Fri Nov 12 13:25:52 EST 2010
   Reporter:  brentrobinson  |       Owner:  brentrobinson
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.6.0
  Component:  FDO API        |     Version:  3.6.0
   Severity:  2              |    Keywords:  SQL Server 2008 database name special character
External_id:                 |
 If SQL Server 2008 database has a name that is all numeric (e.g. "123") or
 contains embedded spaces then the SQL Server Provider cannot access it. If
 the database is opened then feature commands executed against it fail with
 syntax error near "123." messages.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/721>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
