[fdo-trac] #728: Schema Manager: improve "not cached" object list.
trac_fdo at osgeo.org
Wed Nov 24 11:05:02 EST 2010
Reporter: brentrobinson | Owner: brentrobinson
Type: enhancement | Status: closed
Priority: minor | Milestone: 3.6.0
Component: GenericRdbms API | Version: 3.6.0
Severity: 3 | Resolution: fixed
Keywords: Schema Manager cache | External_id:
Changes (by brentrobinson):
* status: new => closed
* resolution: => fixed
Comment:
Revision: 5832
Author: brentrobinson
Date: 11:04:00 AM, Wednesday, November 24, 2010
Message:
Ticket#728: Keep track of reason for not caching a database object for
which a retrieval attempt was made.
Modified : /trunk/Providers/GenericRdbms/Src/PostGis/SchemaMgr/Ph/Mgr.cpp
Modified : /trunk/Providers/GenericRdbms/Src/PostGis/SchemaMgr/Ph/Mgr.h
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_no_meta_test1_PostGIS_master.xml
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_no_meta_test1_SQLServerSpatial_master.xml
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test_ov3_master.txt
Modified : /trunk/Utilities/SchemaMgr/Inc/Sm/Ph/Owner.h
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/728#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
