[fdo-trac] #730: GenericRdbms: cannot select from column with non-ASCII7 name
FDO trac_fdo at osgeo.org
Fri Nov 26 14:51:45 EST 2010
   Reporter:  brentrobinson  |       Owner:  brentrobinson
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.6.0
  Component:  FDO API        |     Version:  3.6.0
   Severity:  2              |    Keywords:  locale non-ASCII7 column name
External_id:                 |
 Steps:
  * Create an MS Access database with one table that has a column with an
 accented (non-ASCII7) character in the name
  * add some rows to the table.
  * Write an FDO API application that does the following:
   * Sets locale to the current one for the machine (setlocale(""))
   * Connects to the database via the ODBC provider
   * creates an FdoISelect on the class for the table.
   * executes the select
   * from the resultant reader, do a ReadNext()
   * try to retrieve the value for the column with accented character.
 An exception is throw with message "Column -1 not found"
Ticket URL: <http://trac.osgeo.org/fdo/ticket/730>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
