[fdo-trac] #731: PostGIS: Add the prefix for the coordinate system name
FDO trac_fdo at osgeo.org
Mon Nov 29 01:14:47 EST 2010
   Reporter:  sunch    |       Owner:  gregboone
       Type:  defect   |      Status:  new
   Priority:  major    |   Milestone:  3.6.0
  Component:  FDO API  |     Version:  3.5.0
   Severity:  3        |    Keywords:
External_id:           |
 In the past, we took value from the spatial_ref_sys:srid column as the
 coordinate system name. Actually, it's not exactlly right to do this. The
 returned 'srid' is just the ID of the spatial reference system as defined
 by the autority cited in the auth_name column.
 http://postgis.org/documentation/manual-svn/ch04.html#spatial_ref_sys
 So it needs to set the value from auth_name as the prefix of the srid to
 compose the intact CS name.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/731>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
