[fdo-trac] #701: MySQL: use varchar for longer string properties
trac_fdo at osgeo.org
Thu Oct 7 08:55:57 EDT 2010
Reporter: brentrobinson | Owner: brentrobinson
Type: enhancement | Status: closed
Priority: major | Milestone: 3.6.0
Component: MySQL Provider | Version:
Severity: 3 | Resolution: fixed
Keywords: String Data Property varchar text | External_id:
Changes (by brentrobinson):
* status: assigned => closed
* resolution: => fixed
Comment:
Revision: 5736
Author: brentrobinson
Date: 1:20:30 PM, Monday, October 04, 2010
Message:
Ticket#701: Continuation of revision 5687 to allow more string properties
to be represented as varchar columns. Before a table is created or
modified, the total row size is check. If it is under the maximum row size
then all new string columns are assigned the varchar type. Otherwise, the
larger string columns (that do not have a default value) are assigned the
text type until the row size is under the maximum.
Modified :
/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/ColumnChar.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/ColumnGeom.h
Modified :
/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Database.cpp
Modified : /trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Database.h
Modified : /trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Table.cpp
Modified : /trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Table.h
Modified :
/trunk/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Ph/Database.cpp
Modified : /trunk/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Ph/Database.h
Modified :
/trunk/Providers/GenericRdbms/Src/PostGis/SchemaMgr/Ph/Database.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/PostGis/SchemaMgr/Ph/Database.h
Modified :
/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/SchemaMgr/Ph/Database.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/SchemaMgr/Ph/Database.h
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoApplySchemaTest.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoApplySchemaTest.h
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp
Modified : /trunk/Utilities/SchemaMgr/Inc/Sm/Ph/Database.h
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Database.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/701#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
