[fdo-trac] #713: Modify FdoSchemaMergeContext to copy class capabilities
FDO trac_fdo at osgeo.org
Mon Oct 25 11:17:34 EDT 2010
 Reporter:  brentrobinson                      |         Owner:  brentrobinson
     Type:  defect                             |        Status:  closed
 Priority:  minor                              |     Milestone:  3.6.0
Component:  FDO API                            |       Version:  3.5.0
 Severity:  3                                  |    Resolution:  fixed
 Keywords:  Feature Schema copy merge context  |   External_id:
Changes (by brentrobinson):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Revision: 5771
 Author: brentrobinson
 Date: 11:15:56 AM, Monday, October 25, 2010
 Message:
 Ticket#713: Copy class capabilites when setting a new class definition
 from an existing definition. Also fixed a small memory leak when
 serializing a data property to XML.
 Modified : /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassCapabilities.h
 Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/ClassCapabilities.cpp
 Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/ClassDefinition.cpp
 Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/713#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
