[fdo-trac] #716: SQLite: Rollback releases the Spatial Index kept
cached in statements generating a crash when are used.
trac_fdo at osgeo.org
Thu Oct 28 14:28:32 EDT 2010
#716: SQLite: Rollback releases the Spatial Index kept cached in statements
Reporter: romicadascalescu | Owner: romicadascalescu
Type: defect | Status: new
Priority: major | Milestone: 3.6.0
Component: SQLite Provider | Version: 3.6.0
Severity: 3 | Keywords:
External_id: |
The issue is: when provider rollbacks a transaction and there is a change
in a spatial index, provider forces a spatial index release, however this
spatial index might be kept as a copy pointer and pointer becomes garbage
when SI is destroyed.
To avoid this problem we need to avoid releasing the spatial indexes at
each rollback and better solution is to empty by force the spatial index
and refresh/refill it. This is a better solution since it will save memory
free-allocate operations, and we just can keep the old allocated memory
and just refresh the data containing the spatial index.
The spatial index is still released in case a table is deleted/renamed or
the data store is closed.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/716>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
