[fdo-trac] #689: SDF crashes on unknown ordering field
FDO trac_fdo at osgeo.org
Sat Sep 4 14:23:58 EDT 2010
   Reporter:  haris     |       Owner:  gregboone
       Type:  defect    |      Status:  new
   Priority:  critical  |   Milestone:  3.5.0
  Component:  FDO API   |     Version:  3.4.0
   Severity:  2         |    Keywords:
External_id:            |
 Using unknown name for order field will cause SDF to crash (uses zero
 pointer).
 Zero pointer access will happen in SdfImpExtendedSelect.cpp in line 519
 'reader->GetComputedIdentifierValue(..)'.
 Reason is that after not finding property name in class provider will
 assume it is computed field and will try to use 'reader' to get value for
 it. But reader is not initialized
Ticket URL: <http://trac.osgeo.org/fdo/ticket/689>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
