[fdo-trac] #799: fdo select command does not escape aliases
FDO trac_fdo at osgeo.org
Thu Dec 1 10:59:24 EST 2011
 Reporter:  jng                |         Owner:  romicadascalescu
     Type:  defect             |        Status:  closed
 Priority:  major              |     Milestone:  3.7.0
Component:  SQLServer Spatial  |       Version:  3.7.0
 Severity:  3                  |    Resolution:  fixed
 Keywords:                     |   External_id:
Changes (by romicadascalescu):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Date: 2011-12-01 07:53:05 -0800 (Thu, 01 Dec 2011) New Revision: 6319
    trunk/Providers/GenericRdbms/Src/Fdo/Other/FdoRdbmsSQLCommand.cpp
 trunk/Providers/GenericRdbms/Src/SQLServerSpatial/Fdo/FdoRdbmsSqlServerProcessors.cpp
 Ticket #760 & #799 Improve SQL Server Spatial
  - avoid flushing cached schema when stored procedures are called
  - added double quotes for aliases in select command
Ticket URL: <http://trac.osgeo.org/fdo/ticket/799#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
