[fdo-trac] #802: mUseNesting is not right
FDO trac_fdo at osgeo.org
Mon Dec 12 03:22:30 EST 2011
   Reporter:  ChristineBao   |       Owner:  thomasknoell
       Type:  defect         |      Status:  new
   Priority:  critical       |   Milestone:  3.7.0
  Component:  ODBC Provider  |     Version:  3.7.0
   Severity:  2              |    Keywords:
External_id:                 |
Comment(by ChristineBao):
 This defect is caused by the mUseNesting flag. It's set to true if the
 filter contains both AND and OR operation
 FdoRdbmsFilterProcessor.cpp:
     // Initialize the member variables that are set by this routine. The
 default
     // value should reflect the current behavior.
     mUseNesting         = true;
     mUseGrouping        = false;
     mAddNegationBracket = false;
     // Analyze the filter.
     FilterAnalyzer filterAnalyzer;
     filter->Process(&filterAnalyzer);
     // Check the result of the analyzing process and set the corresponding
     // member variables that control the generation of the SQL statement
     // from the given filter.
     if ((filterAnalyzer.containsBinaryLogicalOperatorAnd) ||
         (filterAnalyzer.containsBinaryLogicalOperatorOr)     )
         if (filterAnalyzer.isSpatialObjectFilter)
             mUseNesting  = false;
             mUseGrouping = true;
         else
             mUseNesting = filterAnalyzer.containsBinaryLogicalOperatorAnd
 filterAnalyzer.containsBinaryLogicalOperatorOr;
                         !mUseNesting &&
                         filterAnalyzer.containsUnaryLogicalOperatorNot;
 And when the mUseNesting is true, ( is added again and again for the OR
 operator.
     if (mUseNesting)
         AppendString (OPEN_PARENTH, 3);
     if( filter.GetOperation() == FdoBinaryLogicalOperations_And )
         useGrouping  = mUseGrouping;
         if (useGrouping)
         HandleFilter( leftOperand );
         if (useGrouping)
             AppendString (CLOSE_PARENTH, 3);
         AppendString( LOGICAL_AND );
         if (useGrouping)
         HandleFilter( rightOperand );
         if (useGrouping)
     else
         mProcessingOrOperator = true;
         AppendString (LOGICAL_OR, 4);
                 FdoSpatialCondition* leftSpCond =
 dynamic_cast<FdoSpatialCondition*>(leftOperand.p);
         FdoSpatialCondition* rightSpCond =
 dynamic_cast<FdoSpatialCondition*>(rightOperand.p);
         if ( !SupportsSpatialOrNonSpatialOperator() )
             if ((leftSpCond || rightSpCond) && !(leftSpCond &&
 rightSpCond))
                 throw FdoCommandException::Create( NlsMsgGet(FDORDBMS_532,
 "OR not supported in a query when mixing property with spatial filters" )
     if (mUseNesting)
 In this test case, there are a lot of OR operation, so too many ( is added
 into filter string and caused the error.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/802#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
