[fdo-trac] #756: SQLServerSpatial: Expose synonyms as FDO classes.
trac_fdo at osgeo.org
Fri Mar 25 13:25:15 EDT 2011
Reporter: brentrobinson | Owner: brentrobinson
Type: enhancement | Status: assigned
Priority: minor | Milestone: 3.7.0
Component: SQLServer Spatial | Version: 3.7.0
Severity: 3 | Keywords: SQL Server 2008 SQLServerSpatial synonym class
External_id: |
Comment(by brentrobinson):
Revision: 6011
Author: brentrobinson
Date: 1:22:14 PM, Friday, March 25, 2011
Message:
Ticket#756: SQLServerSpatial: synonym handling performance improvements.
In FdoSmPhSynonym:
- skip fetching foreign keys if referenced table is in a different
datastore.
Foreign keys in other datastores are currently not turned into
association
properties anyway.
- Removed fallbacks (for when referenced table cannot be found) which
look
for columns, primary keys, foreign keys and indexes directly owned
by the
Synonym. The Oracle and SQL Server data dictionaries do not relate
synonyms directly to these components.
- Load up synonym reference when asked to load base objects.
The above eliminate a number of selects that always have an empty
results set.
In FdoSmPhSpatialContextGeom
- Fixed bug introduced by J000-BR9, where the geometry column is
determined
to be the base column if it's owning dbObject is differs from the
current
dbObject. This was determined by comparing unqualified names, giving
a false
match if the 2 dbObjects had same name but were in different
datastores. Changed
comparison to be by qualified name.
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/SQLServerSpatial/SqlServerSchemaMgrTests.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/synonyms1_SQLServerSpatial_master.xml
Modified : /trunk/Utilities/SchemaMgr/Inc/Sm/Ph/DbObject.h
Modified : /trunk/Utilities/SchemaMgr/Inc/Sm/Ph/Synonym.h
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGeom.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Synonym.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/756#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
