[fdo-trac] #780: Fix a problem in WMS GetFeatureInfoRequest
FDO trac_fdo at osgeo.org
Wed Sep 7 23:32:27 EDT 2011
   Reporter:  samwang       |       Owner:  gregboone
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.7.0
  Component:  WMS Provider  |     Version:  3.7.0
   Severity:  3             |    Keywords:
External_id:                |
 This submission fixes a problem in WMS GetFeatureInfo command request.
 The problem is that when sending a WMS GetFeatureInfo request, the command
 should take "i", "j" parameter which is the pixel location in horizontal
 and
 vertical direction should be of a integer. However, previous code format
 it as a
  double value which causes most servers return an exception message
 stating that
 input value format is invalid. This submission fixes this problem.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/780>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
