[Fdo-trac] [fdo-trac] #859: Shape provider: crash reading rows
trac_fdo at osgeo.org
Fri Dec 21 07:29:48 PST 2012
Reporter: romicadascalescu | Owner: romicadascalescu
Type: defect | Status: new
Priority: major | Milestone: 3.8.0
Component: SHP Provider | Version: 3.8.0
Severity: 3 | Keywords:
External_id: |
Fixed a crash reading rows in a: SHP record mismatch?
A SHP file has the information inside organized like below:
- Header (100 bytes)
(Rec Number) (Length of Shape)
So normally we can read record by record from the file. The problem show
up when
we have gaps between records.
And that's the problem with this file:
(-1) (unused space)
Now this file had -1 however other files could have any random value.
Also the provider when we read one record we read more records at a time
(it's a
cache mechanism) of max 50 records.
The cache mechanism could not be resynchronized in case of gaps mainly
because
to resynchronize it needed information from the spatial index file (SHX).
To fix this issue make SHP cache mechanism to use SHX data to move ensure
we
read from the right positions the records cached if possible.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/859>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
