[fdo-trac] #815: Ordinates is not released by FdoIMultiPoint when the geometry is reused
FDO trac_fdo at osgeo.org
Fri Feb 10 17:17:18 EST 2012
   Reporter:  romicadascalescu  |       Owner:  romicadascalescu
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:  3.7.0
  Component:  FDO API           |     Version:  3.7.0
   Severity:  2                 |    Keywords:
External_id:                    |
 FDO is recycling the geometries and also the byte arrays used by
 geometries.
 FDO is doing that by calling Reset() on the geometry (see below).
 Now the ordinates pointer was not cleaned up for multi-points (a pointer
 to a memory location having points coordinates). Depending of the number
 of points of the old geometry and the number of points of the new
 geometry, and in case the recycled geometry had less points than the new
 one, FDO was writing more points in ordinates buffer than it should
 (ordinates pointer was nor reallocated to reflect the new bigger
 geometry). This way FDO corrupted memory, sometimes less critical (and
 crash occurred later), sometimes critical and crash showed up as a heap
 corruption
 void FdoFgfMultiPoint::Reset(
     FdoByteArray * byteArray,
     const FdoByte * data,
     FdoInt32 count
 // new code begin
     if (m_ordinates != NULL)
         delete[] m_ordinates;
     m_ordinates = NULL;
 // new code end
     SetFgf(byteArray, data, count);
Ticket URL: <http://trac.osgeo.org/fdo/ticket/815>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
