[fdo-trac] #811: SHP provider: file pointer overflow in the case of large DBF files
FDO trac_fdo at osgeo.org
Thu Jan 19 15:57:24 EST 2012
   Reporter:  danstoica  |       Owner:  gregboone
       Type:  defect     |      Status:  new
   Priority:  major      |   Milestone:  3.6.0
  Component:  FDO API    |     Version:  3.6.0
   Severity:  2          |    Keywords:
External_id:             |
 The following code is faulty for large DBF files (as number of records)
 and large record size:
 SetFilePointer64((FdoInt64)(m_nRecordStart + (nRecord *
 m_DBFHeader.wRecordSize)))
 All the integers involved in the file pointer values are Int32 thus the
 result is an int32 (max_int= 2147483647). In the case of recordNumber =
 700000 a record size of 3070 will be enough to result into a negative
 number for the file pointer.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/811>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
