[fdo-trac] #809: Ambiguous field in FDO query filter in select with joins.
FDO trac_fdo at osgeo.org
Thu Jan 19 23:31:49 EST 2012
 Reporter:  StevenXu         |         Owner:  StevenXu
     Type:  defect           |        Status:  closed
 Priority:  major            |     Milestone:  3.7.0
Component:  SQLite Provider  |       Version:  3.7.0
 Severity:  3                |    Resolution:  fixed
 Keywords:                   |   External_id:  1444194.01
Changes (by StevenXu):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed it in trunk stream with submission
 r6357[https://trac.osgeo.org/fdo/changeset/6357]
 This defect was caused by FDO SQLite provider, when users create select
 with
 joins and use IN condition as the filter, the SQLite provider failed to
 translate the FDO class name in IN condition.
 This submission fixed this problem and one test case was add in unit tests
 to
 verify it.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/809#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
