[Fdo-trac] [fdo-trac] #835: Ubuntu/CMake build patch
trac_fdo at osgeo.org
Mon Jun 11 00:27:03 PDT 2012
Reporter: jng | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Build System | Version: 3.7.0
Severity: 3 | Keywords:
External_id: |
Attached is a patch to ensure clean compilation of FDO 3.7 in the
following environments:
- Ubuntu 12.04 with automake
- Ubuntu 12.04 with CMake + system libs
- CentOS 5.6 with automake
The majority of the patch is CMakeLists.txt/Makefile.am adjustments, but
there is a modification of the ExpressionEngine reader code to fix
compilation errors relating to the use of stdext::hash_map
Ticket URL: <http://trac.osgeo.org/fdo/ticket/835>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
