[fdo-trac] #830: Disposable::GetHashCode() throws overflow exception on Int64
FDO trac_fdo at osgeo.org
Tue May 15 21:28:18 EDT 2012
   Reporter:  gregboone  |       Owner:  gregboone
       Type:  defect     |      Status:  new
   Priority:  major      |   Milestone:  3.7.0
  Component:  FDO API    |     Version:  3.7.0
   Severity:  2          |    Keywords:  GetHashCode
External_id:             |
Description changed by gregboone:
Old description:
> Calling the managed interface function "Disposable::GetHashCode()" can
> result in an overflow exception if the internal pointer is larger than
> Int32.
> svn diff ...\Fdo\Managed\Src\OSGeo\Runtime\Disposable.cpp
>  System::Int32 NAMESPACE_OSGEO_RUNTIME::Disposable::GetHashCode()
> -       return m_imp.ToInt32();
> +    // Solution for overflow issue taken from:
> +    // http://msdn.microsoft.com/en-
> us/library/system.object.gethashcode(v=vs.71).aspx
> +    System::Int64 i64 = m_imp.ToInt64();
> +    return ((System::Int32)(i64) ^ (System::Int32)(i64 >> 32));
New description:
 Int32.
 svn diff Disposable.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/830#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
