[Fdo-trac] [fdo-trac] #853: ODBC: No identity for SQL Server classes not in dbo
FDO trac_fdo at osgeo.org
Tue Nov 13 12:41:08 PST 2012
   Reporter:  brentrobinson  |       Owner:  brentrobinson
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.8.0
  Component:  FDO API        |     Version:  3.8.0
   Severity:  2              |    Keywords:  ODBC SQL Server identity non-dbo
External_id:                 |
 Steps:
  * Create a SQLServer database.
  * Add another schema in addition to dbo
  * add a table to the new schema, and add some columns and a primary key
 column.
  * Create an ODBC DSN for the SQL Server database
  * Create an Fdo ODBC Provider connection to the DSN.
  * Perform an FdoIDescribeschema.
 The class for the table has no identity properties. They should be
 generated from the primary key.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/853>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
