[Fdo-trac] [fdo-trac] #851: ODBC: SQL Server table mappings wrong for non-dbo schemas.
FDO trac_fdo at osgeo.org
Tue Oct 30 12:19:30 PDT 2012
   Reporter:  brentrobinson  |       Owner:  brentrobinson
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.8.0
  Component:  ODBC Provider  |     Version:  3.8.0
   Severity:  2              |    Keywords:  ODBC Schema Mappings table name
External_id:                 |
 Steps:
  * Using ODBC provider create an FdoIConnection to a SQL Server database
 that has tables in more than one feature schema.
  * Create and execute an FdoIDescribeSchemaMapping command.
  * Write the resulting schema mappings to a XML file for viewing.
 The table name mappings for the non-dbo tables are not qualified by
 schema, meaning if these mappings are used as the configuration for the
 connection, these table mappings will point to the dbo schema and pick up
 the wrong or a non-existing table.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/851>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
