[Fdo-trac] [fdo-trac] #871: Cannot build 32-bit/64-bit openssl from the same directory
trac_fdo at osgeo.org
Thu Aug 1 05:28:04 PDT 2013
Reporter: jng | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone:
Component: Build System | Version:
Severity: 3 | Keywords:
External_id: |
Just wanted to see if we can build 32-bit/64-bit trunk FDO from the same
source tree. It fails on openssl because nmake uses the same tmp directory
for both 32-bit and 64-bit.
Attached is a patch to define platform-specfic tmp directories in the
nmake calls.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/871>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
