[Fdo-trac] [fdo-trac] #861: table-valued inline functions in SpatialContextReader
trac_fdo at osgeo.org
Wed Jan 23 03:20:08 PST 2013
Reporter: gBecker | Owner: danstoica
Type: defect | Status: new
Priority: major | Milestone: 3.8.0
Component: SQLServer Spatial | Version: 3.7.0
Severity: 3 | Keywords:
External_id: |
I have quite some problems with "table-valued function" in SQL Server that
return tables which contains geometry-columns. I don't think that "table-
valued Function" are supported by FDO or MapGuide OpenSource and therefore
I do not need them to be accessed by MapGuide ( I use them alongside SQL
Server feature CDC - ChangeDataCapture ).[[BR]]
The problem is that when I try to create a FeatureSource in Maestro or
Infrastructure MapServer 2013 I get an error and therefore cannot save the
FeatureSource. I think the root problem occurs when trying to access the
spatial context. The error says that no parameters where send to the
Table-Valued Funtion xxx. So it seems that MapGuide/FDO try to access
these function to gather information even though these funtions are not
supported. When preview the FeatureSource I get this message:[[BR]]
''An exception occurred in FDO component. Error occurred in Feature Source
( ... ): RDBMS: [Microsoft][SQL Server Native Client 10.0][SQL Server]
An insufficient number of arguments were supplied for the procedure or
function 'FFM_Fes.cdc.fn_cdc_get_all_changes_dbo_fes_Objects'''[[BR]]
I have turned on trace logging for the FDO SQL Server Provider! Like I'm
assuming the table-valued function is queried for retrieving the sptial
reference system. This throws the error since there are now parameters
send to the function:[[BR]]
select top 1 [Geometrie].STSrid as srid from
"FFM_Fes"."cdc"."fn_cdc_get_all_changes_dbo_fes_Objects"
Just before a query was executed which returns a table with all objects in
the database that contains a geometry column. The table also has a column
"object_type" that determine the type of the returned objects. The table-
valued function is of type "if" which means it is a "SQL inline table-
valued function". When the FDO SQL Server Provider loops over this table
to determine the SRID for every object like above the error is
thrown.[[BR]]
'''Solution'''[[BR]]
I think the proper way would be that FDO/MapGuide recognize these
functions and pass by while gathering the required data.
It would be easy to extend the existing query in
http://trac.osgeo.org/fdo/browser/trunk/Providers/GenericRdbms/Src/SQLServerSpatial/SchemaMgr/Ph/Rd/SpatialContextReader.cpp
line 284
with a filter in WHERE-clause to not return table-valued inline functions
(lower(a.type) <> 'if') line 303 :[[BR]]
select 0 as srid,
c.name collate latin1_general_bin as geomusername,
a.name collate latin1_general_bin as geomtablename,
b.name as geomcolumnname,
e.bounding_box_xmin as xmin,
e.bounding_box_ymin as ymin,
e.bounding_box_xmax as xmax,
e.bounding_box_ymax as ymax,
f.name as type,
lower(a.type) as object_type,
g.name as indexname
from "FFM_Fes".sys.objects a
INNER JOIN "FFM_Fes".sys.columns b ON ( a.object_id = b.object_id )
INNER JOIN "FFM_Fes".sys.schemas c ON ( a.schema_id = c.schema_id )
LEFT OUTER JOIN "FFM_Fes".sys.index_columns d ON ( a.object_id =
d.object_id and b.column_id = d.column_id )
LEFT OUTER JOIN "FFM_Fes".sys.spatial_index_tessellations e ON (
d.object_id = e.object_id and d.index_id = e.index_id )
INNER JOIN "FFM_Fes".sys.types f ON ( b.user_type_id = f.user_type_id )
LEFT OUTER JOIN "FFM_Fes".sys.indexes g ON ( a.object_id = g.object_id
and d.index_id = g.index_id )
where (f.name in ( 'geometry','geography' ) or e.object_id is not null)
and lower(a.type) <> 'if'
order by c.name collate latin1_general_bin asc, a.name collate
latin1_general_bin asc, b.column_id asc
I don't know if there are other places in code where to change this query.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/861>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
