[Fdo-trac] [fdo-trac] #869: SQL Azure Support for SQLServer Provider
trac_fdo at osgeo.org
Wed Jul 31 07:22:10 PDT 2013
Reporter: crispinatime | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone: 3.8.0
Component: FDO API | Version: 3.8.0
Severity: 3 | Keywords:
External_id: |
Currently the SQLServer Provider will not connect to an online SQL Azure
hosted database.
SQL Azure solution contains the same datatypes, indexes etc (including
spatial Geometry and Geography). However, there are design elements that
are not relevant when not running on physical hardware that mean some of
the SQLServer commands and capabilities used in the FDO provider code
cause connection and schema issues.
This ticket contains a brief description about some changes to make the
provider works with SQL Azure. These have been tested with a sample FDO
client (MapGuide v2.5).
Note that these changes only make the connection and reader elements of
FDO work with SQL Azure. Schema swapping (use of "USE" is not possible -
requires database re-connection) so it was not possible to pass the schema
creation tests. Therefore to utilise the reader required a database to
already exist.
SQL Azure databases may be created for free to use for testing with a
Microsoft account. See [http://www.windowsazure.com/en-us/pricing/free-
trial/]
[[BR]]
The following issues are addressed in the accompanying patch file:
1. SQL Azure Does Not Support FILEGROUP_NAME
FILEGROUP_NAME( groupId ):
This is used in FDO and returns the name of the groupId. It does the
query over the system table sys.filegroups such as:
select name from sys.filegroups where data_space_id= [groupId]
Both FILEGROUP_NAME function and sys.filegroups table haven’t been
supported at current SQL Azure version.
Solution: Temporarily replace it with the constant name ‘primary’
(Still need another permanent solution!)
[[BR]]
2. SQL Azure Does Not Support Access to Other Databases
[DatabaseName].dbo.syscolumns
Solution: Assuming the restriction is to one database within Azure (part
of the connection string), just use the current database by removing the
[DatabaseName] part like:
databasename.dbo.syscolumns -> dbo.syscolumns.
[[BR]]
3. SQL Azure Does Not Support 'sysindexes' Table
sysindexes
Solution: System table named sysindexes may be replaced by sys.indexes in
SQL Azure.
As a result, some SQL will be updated as follows:
sysindexes.id -> sys.indexes.object_id
sysindexes.indid -> sys.indexes.index_id
In the patch file the changes for SQLAzure have been wrapped in a
preprocessor IFDEF statement to allow for different builds. Ideally the
code can be reviewed and a single common set of SQL created for the
provider but this may not be possible.
The "SQLServerSpatialSchemaMgr" project requires the following pre-
processor directive to be defined in order to build the provider for SQL
Azure environment.
#ifdef SQL_AZURE_MODE
References:[[BR]]
[http://blog.sqlauthority.com/2010/06/04/sql-server-generate-database-
script-for-sql-azure/]
[http://blogs.architectingconnectedsystems.com/blogs/cjg/archive/2011/12/26
/SQL-Azure-supported-tables_2F00_views.aspx]
Ticket URL: <http://trac.osgeo.org/fdo/ticket/869>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
