[Fdo-trac] [fdo-trac] #896: Add OpenSSL clause to the LGPL license
FDO trac_fdo at osgeo.org
Tue Oct 7 13:08:35 PDT 2014
   Reporter:  johanvdw  |       Owner:  gregboone
       Type:  defect    |      Status:  new
   Priority:  major     |   Milestone:  3.8.0
  Component:  FDO API   |     Version:  3.8.0
   Severity:  3         |    Keywords:
External_id:            |
 Hello,
 Currently FDO and Mapguide are released under the LGPL license. However
 this license is not completely compatible with OpenSSH which is part of
 FDO.
 It would be better to include an OpenSSL exception to the license. Such an
 exception will be needed if FDO is ever to be part of Debian and derived
 distributions(it will always be rejected otherwise[1] ).
 An example (based on a text from [2]):
  * In addition, as a special exception, the copyright holders give
  * permission to link the code of portions of this program with the
  * OpenSSL, and distribute linked combinations including the two.
  * You must obey the GNU Lesser General Public License in all respects
  * for all of the code used other than OpenSSL.  If you modify
  * file(s) with this exception, you may extend this exception to your
  * version of the file(s), but you are not obligated to do so.  If you
  * do not wish to do so, delete this exception statement from your
  * version.  If you delete this exception statement from all source
  * files in the program, then also delete it here.
 Regards,
 Johan
 [1]https://ftp-master.debian.org/REJECT-FAQ.html
 [2]https://people.gnome.org/~markmc/openssl-and-the-gpl.html
Ticket URL: <http://trac.osgeo.org/fdo/ticket/896>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
