[Fdo-trac] [fdo-trac] #899: PostgreSQL provider does not support other schema than public when fdometadata is activated
trac_fdo at osgeo.org
Fri Oct 31 02:28:08 PDT 2014
Reporter: bscott | Owner: badreddinekaroui
Type: defect | Status: new
Priority: blocker | Milestone: 3.8.0
Component: PostgreSQL Provider | Version: 3.8.0
Severity: 3 | Keywords:
External_id: |
To be able to insert/update data into a view, FDO require a primary key.
With Oracle we can set a disable unique pkey constraint, with SQLServer we
can use a view with schema binding but with PostgreSQL there is no
workaround to make FDO find a primary key.
The only way i've found is to populate all the fdo metadata tables. Works
fine except if the client tables belongs to another schema than public.
Included is a patch that fix this issue.
The patch has been created on the Utilities directory
Ticket URL: <http://trac.osgeo.org/fdo/ticket/899>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
