[Fdo-trac] [fdo-trac] #895: SQLite unit test deadlock
trac_fdo at osgeo.org
Sun Sep 28 11:18:59 PDT 2014
Reporter: jng | Owner: traianstanev
Type: defect | Status: new
Priority: critical | Milestone:
Component: SQLite Provider | Version:
Severity: 1 | Keywords:
External_id: |
Running the SQLite unit tests on Linux from trunk produces a deadlock.
In my tests thus far, the unit tests will consistently freeze at
SelectTest.TestViewSelects. This happens on CentOS 6.5 and Ubuntu
12.04/14.04
Running the UnitTest executable under gdb and breaking at the point of
deadlock reveals this stack trace (this is from Ubuntu 14.04 64-bit, but
given the consistency the stack trace would probably be similar for the
other Linux variants).
Program received signal SIGINT, Interrupt.
__lll_lock_wait () at
../nptl/sysdeps/unix/sysv/linux/x86_64/lowlevellock.S:135
135 ../nptl/sysdeps/unix/sysv/linux/x86_64/lowlevellock.S: No such
file or directory.
(gdb) bt
#0 __lll_lock_wait () at
#1 0x00007ffff6af9657 in _L_lock_909 () from /lib/x86_64-linux-
gnu/libpthread.so.0
#2 0x00007ffff6af9480 in __GI___pthread_mutex_lock (mutex=0x90d710)
at ../nptl/pthread_mutex_lock.c:79
#3 0x00007ffff4f3a3b6 in CriticalSectionHolder::CriticalSectionHolder
(this=0x7fffffffd970,
cs=0x90d710) at SltProvider.h:111
#4 0x00007ffff4f29dfa in SltConnection::GetMetadata (this=0x90d6c0,
table=0x7d86b8 "MainTable")
at SltProvider.cpp:1701
#5 0x00007ffff4f12ba3 in SltMetadata::ProcessViewProperties
(this=0x8abd20, pTable=0x90d5a8,
pstmtView=0x7fffffffdc88) at SltMetadata.cpp:714
#6 0x00007ffff4f11f5d in SltMetadata::BuildMetadataInfo (conn=0x90d6c0,
lst=0x0)
at SltMetadata.cpp:617
#7 0x00007ffff4f24a78 in SltConnection::DescribeSchema (this=0x90d6c0,
classNames=0x0,
makeACopy=true) at SltProvider.cpp:743
#8 0x00007ffff4f3b402 in SltDescribeSchema::Execute (this=0x819ad0) at
SltCommands.h:127
#9 0x0000000000433097 in SelectTest::TestViewSelects (this=0x7c39a0) at
SelectTest.cpp:952
#10 0x0000000000442c96 in CppUnit::TestCaller<SelectTest,
CppUnit::NoExceptionExpected>::runTest (
this=0x7c3530)
at
/home/vagrant/scripts/fdo_build_area/Thirdparty/linux/cppunit/include/cppunit/TestCaller.h:166
I suspect r7133 introduced this defect. Perhaps this method call chain
causes the CriticalSectionHolder to acquire the `m_csMd` critical section
more than once causing a perpetual wait on a lock that will never be
released?
Ticket URL: <http://trac.osgeo.org/fdo/ticket/895>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
