[Fdo-trac] [fdo-trac] #920: SQL Server computed column not implemented as "read only"
FDO trac_fdo at osgeo.org
Tue Jul 26 03:38:31 PDT 2016
   Reporter:  gBecker            |      Owner:  danstoica
       Type:  defect             |     Status:  new
   Priority:  major              |  Milestone:  4.0.0
  Component:  SQLServer Spatial  |    Version:  4.0.0
   Severity:  3                  |   Keywords:
External ID:                     |
 When using computed columns in SQLServer these columns are not implemented
 as "ReadOnly"-properties in FDO Provider.
 So, auto-generating a form from FDO class definition is insufficent at
 this point, because it would allow the user to enter a value for this
 (computed) property. For an example you can see this behaviour in FDO
 Toolbox when trying to add a new feature to a class with an auto-genrated
 column.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/920>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
