[Fdo-trac] [fdo-trac] #918: WMS provider segfaults when creating connection, crashing client application
trac_fdo at osgeo.org
Mon May 23 09:44:23 PDT 2016
application
Reporter: jng | Owner: gregboone
Type: defect | Status: new
Priority: blocker | Milestone: 4.1.0
Component: WMS Provider | Version: 4.0.0
Severity: 1 | Keywords:
External ID: |
In MapGuide, the WMS provider segfaults when attempting to create a FDO
connection, crashing the mgserver process. The stack trace when run
through gdb does not provide any useful information other than something
in `libWMSProvider.so` (the function shows as `??` on CentOS, on Ubuntu 14
the function shows as `_init`) is the cause of the segfault.
Through trial and error of various FDO trunk revisions (to determine when
things started to break), it was identified the offending revision to be
r7257. This revision updated the vcxproj file on Windows, but failed to
update the matching Makefile.am files for Linux. As a result, the WMS
provider got compiled with what I gather to be undefined symbols that is
the cause of the segfault (how gcc/ld didn't catch this or treat this as
an error I will never know!)
Attached is a patch to include the new .cpp/.h files in the respective
Makefile.am files.
This needs to be applied on trunk and 4.1 branches and is currently
blocking the release of MapGuide Open Source 3.1, which does not have a
functional WMS provider due to this issue.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/918>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
