[Fdo-trac] [fdo-trac] #951: setenvironment.bat: Support VS2017 (with 2015 compiler workload)
trac_fdo at osgeo.org
Wed Apr 18 16:55:27 PDT 2018
Reporter: jng | Owner: jng
Type: defect | Status: closed
Priority: major | Milestone: 4.1.0
Component: Build System | Version: 4.1.0
Severity: 3 | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"7652" 7652]:
#!CommitTicketReference repository="" revision="7652"
For VS2017 (with MSVC 2015 compiler workload) the current
setenvironment.bat does not properly set up the build environment.
This updates setenvironment.bat to test for VS2017 paths first and if
present, call its vcvarsall.bat with the -vcvars_ver=14.0 argument to
instruct it to use the Visual C++ 2015 (v140) toolset.
Fixes #951
Ticket URL: <https://trac.osgeo.org/fdo/ticket/951#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
