[Fdo-trac] [fdo-trac] #944: CMake: Prepare providers.xml for UnitTest executables
FDO trac_fdo at osgeo.org
Sun Feb 11 02:44:21 PST 2018
   Reporter:  jng           |      Owner:  jng
       Type:  enhancement   |     Status:  assigned
   Priority:  major         |  Milestone:
  Component:  Build System  |    Version:
   Severity:  3             |   Keywords:
External ID:                |
 Currently, UnitTest executables produced by CMake cannot be run without
 first doing:
 sudo make install
 export LD_LIBRARY_PATH=/usr/local/fdo-x.y.z/lib:$LD_LIBRARY_PATH
 This is because there is no `providers.xml` present in the UnitTest's
 output directory (because the default one is for Windows), so the next
 place to look is the FDO installatio ndirectory, which can easily get out
 of date with respect to what you're currently building.
 The UnitTest's `CMakeLists.txt` should prepare an app-local copy of this
 file
Ticket URL: <https://trac.osgeo.org/fdo/ticket/944>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
