[Fdo-trac] [fdo-trac] #667: UpdateVersion.exe requires UAC prompt
trac_fdo at osgeo.org
Mon Jan 15 00:02:49 PST 2018
Reporter: jng | Owner: gregboone
Type: defect | Status: closed
Priority: minor | Milestone:
Component: Build System | Version: 3.5.0
Severity: 3 | Resolution: fixed
Keywords: build, uac | External ID:
Comment (by jng):
In [changeset:"7615" 7615]:
#!CommitTicketReference repository="" revision="7615"
Merged revision(s) 7534-7563 from trunk:
Fix a problem that the SHP file cannot be read if the SHP file has been
opened for writing.
Reason:
If one connection is writing to the SHP file and the other connection
connects to the same SHP file for reading and writing,
ShpFileSet::GetSpatialIndex(...) function will not work properly. This
function will close the idx file and try to delete it.
But the deletion will not be performed since the idx file is locked at
this moment. So "mSSI" member variable holds the invalid
file handler after the CloseFile() function is called. Later, "mSSI" is
used to manipulate the index file, an exception is thrown.
Fix:
If the idx file cannot be deleted, "mSSI" member is deleted and set to
NULL. Later, "mSSI" member will be created again if its value
is NULL.
#931: WMS Connection returns SSL connect error
Currently, the SSL version we set for curl is 1, which is
CURL_SSLVERSION_TLSv1. Now we encounter a case that the WMS server is
using TLS 1.2, but we get error CURLE_SSL_CONNECT_ERROR when connecting to
this server. It works when setting SSL version to CURL_SSLVERSION_DEFAULT.
I haven't found the root cause yet.
I submit the change to make it works. We may need to add the SSL version
to configuration document later.
#932 WFS provider: value of number attribute is changed
When connecting to a WFS server who has an attribute in xsd:long format,
the value which is bigger than 2147483647 (e.g. 2555555556) is shown
incorrectly in Map3D (2147483647).
It is because we use wtol to convert a string a long number. The max value
is 2147483647. To fix the issue, we need to add a new method ToInt64 in
class FdoStringP.
Continue to fix #932. Use new API FdoStringP::ToInt64 in method
FdoXmlFeatureReaderImpl::GetInt64().
#934: Fix test baseline for GenericRdbms test suite
- General: Remove whitespace in various master text files that were
failing content comparisons in various test cases
- MySQL:
- MySqlReaderTest::TestExceptionalCase: Fix incorrect case on SQL
query
- ODBC:
- OdbcConnectionUtil::SetupMySqlDSN: Re-enable MySQL DSN registration.
The test ODBC test suite for MySQL passes with the current MySQL
Connector/ODBC, so I don't know why DSN registration was disabled.
- SQLServerSpatial:
- SqlServerConnectTests::do_rdbi_connect: Change the connection string
to use Uid/Pwd instead of Trusted_Connection. This allows us to run this
particular test case against SQL Server 2017 on Linux. The old test has
been #ifdef'd out through a new SQL_SERVER_XPLAT preprocessor macro that
is defined by default (meaning Uid/Pwd is now tested by default)
Current suites with known test failures as of this commit is now:
- MySQL: 1 (down from 3)
- ODBC (MySQL): 0 (down from 49)
- PostgreSQL: 2 (down from 4)
- SQLServerSpatial: 2 (down from 6)
#934: Fix SchemaMgrTests.testConfigError failing for SQLServerSpatial. The
configuration document being loaded (and expecting to fail) failed with a
different error because the configuration document was not fed through
OverrideBender.xslt (like other test configuration documents). This meant
that the test case was trying to load OracleProvider.dll causing the test
to fail with a different error than the one expected.
The current UpdateVersion.exe bombards UAC prompts every time it is run.
Apparently just building a new version from source produces an
UpdateVersion.exe that does not have this annoyance.
Fixes #667
Fix xalan build failure on Debug|x64
Fix output/intermediate path for UnitTestPostGIS to be consistent with
other GenericRdbms-based unit test executables.
#934: The cause of all the content comparison test failures is due to
inconsistency in how UnitTestUtil::PrintException outputs exception
messages in release and debug modes. This submission establishes the
correct baseline for master content and ensures UnitTestUtil adheres to it
in both release and debug.
#934: Clean up apply_schema_test6_master.txt it had debug-only exception
messages
#934: Update LogicalPhysicalFormatter.xslt to scrub out file/line number
prefix on error messages. Debug FDO exceptions will carry this information
and isn't going through UnitTestUtil::PrintException so they are being
written out to schema content, failing the comparison tests.
#934: Update LogicalPhysicalFormatter.xslt only scrub out the file/line
number if it is actually present in the error message.
Modify datastore query to use HAS_DBACCESS to cut off inaccessible
databases.
Fixes #933
Modify UnitTestUtil::CreateDB to allow creating data stores without FDO
metadata tables.
Fix SQL Server date columns not appearing in schema.
Patch by Bruno Scott. Unit test by me.
Fixes #875
Use locale-independent date format for handling dates in SQL Server.
Fixes #766
Mark as read-only data properties whose mapped SQL Server physical columns
are computed.
Includes unit test to verify computed columns come out as read-only data
properties.
Fixes #920
OGR Provider changes:
- Make sure unit test project builds in Debug|x64
- Add test case to check that DescribeSchema works with VRT data sources
- Fix access violation in insert command discovered running unit tests
under Debug|x64. The insert command was using "new OGRFeature" instead of
OGRFeature::Create() which meant allocation and destruction was occurring
on different heaps.
#937:
- Constant-ify "FID" and "GEOMETRY" special property names
- Add macros for:
- Ensuring an open connection (ENSURE_OPEN_CONNECTION)
- Throwing an equivalent FDO exception if CPLGetErrorMsg() is a non-
empty string after certain GDAL/OGR API calls (CHECK_CPL_ERROR)
- Throw if we have non-empty strings from CPLGetErrorMsg() after
enumerating OGR layers and in OgrFdoUtil::ConvertClass()
- Add extra VRT unit tests to test additional VRT data sources and to
verify that exceptions are now thrown when describing the schema of
various invalid VRT data sources.
#937: Include VrtTest in Makefile.am
#937: Ensure property names are tilde-fied by the OGR provider as dots in
FDO property names are illegal. Add a test VRT that demonstrates the
problem and unit tests to verify the fix.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/667#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
