[Fdo-trac] [fdo-trac] #912: Update GDAL library to version 2.2
    trac_fdo at osgeo.org
    Mon Jan 15 06:15:47 PST 2018
 Reporter:  kwi                    |        Owner:  jng
     Type:  task                   |       Status:  closed
 Priority:  major                  |    Milestone:  4.1.0
Component:  Thirdparty Components  |      Version:  4.0.0
 Severity:  1                      |   Resolution:  fixed
 Keywords:  gdal                   |  External ID:
Comment (by jng):
 In [changeset:"7617" 7617]:
 #!CommitTicketReference repository="" revision="7617"
 Merged revision(s) 7613 from trunk:
 Upgrade GDAL to 2.2.3 and fix affected providers and unit tests.
 I gave up trying to merge this from gdal2 sandbox (svn just keeps dropping
 out probably due to volume of files involved, resulting in incomplete
 merges)
 So I've gone with the alternative approach of deleting the Thirdparty/gdal
 on my trunk WC and overlaying everything from my gdal2 sandbox WC into it,
 marking everything missing as "deleted" and everything unknown as "added",
 achieving the same effect of a merge but hopefully without the dropouts.
 If you see this message then everything went through :)
 Fixes #912
Ticket URL: <https://trac.osgeo.org/fdo/ticket/912#comment:4>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
