[Fdo-trac] [fdo-trac] #761: Full 64-bit Linux support
trac_fdo at osgeo.org
Wed Jan 24 02:55:22 PST 2018
Reporter: rafael | Owner: jng
Type: enhancement | Status: new
Priority: major | Milestone: 3.8.0
Component: FDO API | Version: 3.5.0
Severity: 2 | Resolution:
Keywords: | External ID:
Changes (by jng):
* owner: gregboone => jng
* status: assigned => new
Comment:
As of this comment, the only remaining roadblocks for 64-bit Linux support
that I can see based on failing/segfaulting unit tests are:
* PostGIS: Replace usages of `unsigned long` (especially if they're being
`sizeof()`'d) with an equivalently sized data type throughout the PostGIS
rdbi driver. This is a different size on 64-bit Linux as opposed to
windows (32 and 64-bit) and 32-bit Linux. The driver also appears to be
selecting the wrong PG data types to use on 64-bit Linux based on unit
test failures around overflowing values (eg. PostgreSQL will report: <some
astronomical value> is too small for the type `smallint`)
* SHP: Replace usages of `long` and `unsigned long` (especially if
they're being `sizeof()`'d) with an equivalently sized data type
throughout the ShpSpatialIndex project. Same reason as PostGIS, different
size on 64-bit Linux.
King Oracle has more underlying problems (#562 and #649) before we can
even consider whether it works on 64-bit Linux.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/761#comment:4>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
