[Fdo-trac] [fdo-trac] #940: Get CMake build working again
    trac_fdo at osgeo.org
    Thu Jan 25 23:12:04 PST 2018
 Reporter:  jng           |        Owner:  jng
     Type:  task          |       Status:  assigned
 Priority:  major         |    Milestone:
Component:  Build System  |      Version:
 Severity:  3             |   Resolution:
 Keywords:                |  External ID:
Description changed by jng:
Old description:
> * ~~Fix broken CMakeLists.txt~~
>  * ~~Verify we can run unit tests in CMake build.~~
>  * ~~CMake-ify the King Oracle provider~~
>  * ~~Fix message catalogs not being copied (`make install` currently only
> installs `SmMessage.cat`)~~
>  * ~~Fix `com` directory not being copied to `/usr/local/fdo-x.y.z/lib`~~
>  * ~~Ensure library targets are named consistently like their windows
> counterparts~~
>  * ~~Build with ASAN (`-fsanitize=address`) in debug mode~~
>  * ~~Investigate how to strip binaries in release mode~~
>  * ~~Investigate how to use CPack to produce SDK tarballs~~ and deb
> packages
>  * Integrate support for running `cppcheck` against the source
>  * Stretch goal: Functional windows configuration (that we can then
> integrate vcpkg for external thirdparty libraries)
New description:
 counterparts~~
 packages
  * Add some wrapper scripts to streamline the CMake build with granularity
 over whether to build against system or internal thirdparty libraries
Ticket URL: <https://trac.osgeo.org/fdo/ticket/940#comment:11>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
