[Fdo-trac] [fdo-trac] #945: OGR Provider: Verify attribute and spatial filters can play nicely together
FDO trac_fdo at osgeo.org
Wed Mar 14 09:31:46 PDT 2018
 Reporter:  jng           |        Owner:  jng
     Type:  defect        |       Status:  closed
 Priority:  major         |    Milestone:  4.1.0
Component:  OGR Provider  |      Version:
 Severity:  3             |   Resolution:  fixed
 Keywords:                |  External ID:
Comment (by jng):
 In [changeset:"7646" 7646]:
 #!CommitTicketReference repository="" revision="7646"
 Merged revision(s) 7638, 7640-7645 from trunk:
 Fix incorrect parameter names in CMake build scripts
 Fix bash-isms in cmake_bootstrap.sh and just inline the contents of
 setenvironment.sh into this script instead of sed patching and source-ing
 the patched script
 Use . instead of source in cmake_build.sh and enable --use-ld-gold switch
 for linking with gold instead of ld
 Gracefully handle evaluation of identifiers containing mixed quotes
 instead of segfaulting. Fixes #946
 #946: Some explanation as to why the OGR provider test suite was the home
 for this new test
 Added OGR unit test to verify spatial and regular filters when combined do
 play nicely together. Fixes #945
 Don't advertise insert/update/delete in command capabilities if OGR
 connection is read-only. Includes unit tests to verify. Fixes #938
Ticket URL: <https://trac.osgeo.org/fdo/ticket/945#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
