[Fdo-trac] [fdo-trac] #938: If readonly = true, don't advertise insert/update/delete as supported in capabilities
trac_fdo at osgeo.org
Wed Mar 14 09:31:46 PDT 2018
capabilities
Reporter: jng | Owner: jng
Type: defect | Status: closed
Priority: major | Milestone:
Component: OGR Provider | Version:
Severity: 3 | Resolution: fixed
Keywords: | External ID:
Comment (by jng):
In [changeset:"7646" 7646]:
#!CommitTicketReference repository="" revision="7646"
Merged revision(s) 7638, 7640-7645 from trunk:
Fix incorrect parameter names in CMake build scripts
Fix bash-isms in cmake_bootstrap.sh and just inline the contents of
setenvironment.sh into this script instead of sed patching and source-ing
the patched script
Use . instead of source in cmake_build.sh and enable --use-ld-gold switch
for linking with gold instead of ld
Gracefully handle evaluation of identifiers containing mixed quotes
instead of segfaulting. Fixes #946
#946: Some explanation as to why the OGR provider test suite was the home
for this new test
Added OGR unit test to verify spatial and regular filters when combined do
play nicely together. Fixes #945
Don't advertise insert/update/delete in command capabilities if OGR
connection is read-only. Includes unit tests to verify. Fixes #938
Ticket URL: <https://trac.osgeo.org/fdo/ticket/938#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
