[Fdo-trac] [fdo-trac] #953: OGR Provider: Support schema name other than "OGRSchema"
trac_fdo at osgeo.org
Wed May 2 10:07:17 PDT 2018
Reporter: jng | Owner: jng
Type: enhancement | Status: closed
Priority: major | Milestone:
Component: OGR Provider | Version: 4.1.0
Severity: 3 | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"7656" 7656]:
#!CommitTicketReference repository="" revision="7656"
Add support for a new optional DefaultSchemaName property, which if
specified will be used as the default schema name instead of "OGRSchema"
The primary motivation for this feature is to allow for OGR connections to
SHP files to present the same schema/class structure and naming as SHP
connections through its dedicated provider (the only real difference is in
the schema name, which OGR had hard-coded as "OGRSchema" until now), which
can then facilitate downstream tooling support in MapGuide to easily
"swap" a SHP Feature Source to an equivalent OGR Feature Source and vice-
versa. This can also apply for other data formats that are supported in
both OGR and its dedicated FDO provider
A new unit test is included to exercise this new connection property
Fixes #953
Ticket URL: <https://trac.osgeo.org/fdo/ticket/953#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
