[Fdo-trac] [fdo-trac] #955: OGR Provider: Data reader returns incorrect property names
FDO trac_fdo at osgeo.org
Tue May 8 08:45:44 PDT 2018
   Reporter:  jng           |      Owner:  jng
       Type:  defect        |     Status:  assigned
   Priority:  major         |  Milestone:  4.1.0
  Component:  OGR Provider  |    Version:  4.1.0
   Severity:  3             |   Keywords:
External ID:                |
 If you do a select aggregates with an expression (eg: {{{COUNT(FID)}}}
 when looping through the properties of the returned data reader, it does
 not return the expression alias you specified as the property name.
 Instead, an OGR-computed property name is returned. This breaks the
 expected flow of an FDO client application consuming a data reader result
 for a select aggregate operation.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/955>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
