[Fdo-trac] [fdo-trac] #455: OGR Provider: Investigate switching string conversion functions to always assume UTF-8 enocded strings
trac_fdo at osgeo.org
Fri May 18 06:50:13 PDT 2018
Reporter: traianstanev | Owner: traianstanev
Type: defect | Status: closed
Priority: major | Milestone:
Component: OGR Provider | Version: 3.4.0
Severity: 3 | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"7670" 7670]:
#!CommitTicketReference repository="" revision="7670"
Replace wchar_t <-> char conversion routines in the OGR provider with
calls to GDAL's CPLRecodeXXX family of string conversion functions
instead. In addition, add support for a new optional "DataSourceEncoding"
connection parameter that allows a user to declare the encoding for a data
source where such encoding cannot be inferred by the underlying OGR
driver. When set, this declares the encoding of the [char] side of any
wchar_t <-> char conversion. If not set, the [char] encoding defaults to
UTF-8.
New unit tests have been added (with a test MapInfo tab file graciously
provided by Geograf A/S) to verify that TAB files with unicode characters
in property names and property values are not scrambled when connecting
with the encoding (ISO-8859-1 for this tab file) specified up front. All
other existing tests still pass with this change.
Special thanks to Hans Milling of Geograf A/S for testing, review of these
changes and providing the test data to add to the ever growing test suite
for the OGR provider.
Fixes #455
Fixes #66
Ticket URL: <https://trac.osgeo.org/fdo/ticket/455#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
