[Fdo-trac] [fdo-trac] #958: build.bat attempts to build PostgreSQL provider even if libpq not set up with setenvironment.bat
FDO trac_fdo at osgeo.org
Wed Oct 3 07:01:32 PDT 2018
   Reporter:  jng           |      Owner:  jng
       Type:  defect        |     Status:  assigned
   Priority:  minor         |  Milestone:
  Component:  Build System  |    Version:
   Severity:  3             |   Keywords:
External ID:                |
 ArcSDE, KingOracle and MySQL providers properly check for their respective
 environment variables to determine if their respective child `build.bat`
 should be called.
 This check is not done for PostgreSQL, as a result the root `build.bat`
 can fail if one did not set up the correct path to libpq in
 `setenvironment.bat`
Ticket URL: <https://trac.osgeo.org/fdo/ticket/958>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
