[Fdo-trac] [fdo-trac] #949: Check if joining to pg_authid is necessary for listing materialized views
trac_fdo at osgeo.org
Tue Dec 24 16:50:23 PST 2019
Reporter: jng | Owner: jng
Type: task | Status: closed
Priority: major | Milestone: 4.1.0
Component: PostgreSQL Provider | Version: 4.1.0
Severity: 3 | Resolution: fixed
Keywords: | External ID:
Comment (by jng):
In [changeset:"7955" 7955]:
#!CommitTicketReference repository="" revision="7955"
Merged revision(s) 7952-7954 from trunk:
Merged revision(s) 7951 from branches/4.1:
#893: Refine the vndr_info reporting for MySQL driver to report the
correct version number for MariaDB, allowing the full spatial capability
suite to light up for the MySQL provider when connecting to MariaDB
Remove join to pg_authid in table/view listing query. It does not appear
to be necessary and our materialized view test still passes.
Fixes #949
Ticket URL: <https://trac.osgeo.org/fdo/ticket/949#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
