[Fdo-trac] [fdo-trac] #967: If building FDO with internal openssl/libcurl, building libcurl insists on linking to system openssl instead of internal copy
trac_fdo at osgeo.org
Fri Feb 1 03:52:42 PST 2019
Reporter: jng | Owner: jng
Type: defect | Status: closed
Priority: major | Milestone:
Component: Build System | Version:
Severity: 3 | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* status: reopened => closed
* resolution: => fixed
Comment:
In [changeset:"7826" 7826]:
#!CommitTicketReference repository="" revision="7826"
The previous attempt to get libcurl to build against internal openssl
didn't work because internal openssl does not produce an installation
layout that can be directly recognized by the --with-ssl switch for
libcurl's configure script. This commit configures openssl to install to
the "_install" directory. The build.sh of libcurl will invoke configure
with this directory for --with-ssl if it exists.
Also the cmake_bootstrap.sh builds libcurl before openssl, which is the
wrong order. So that is fixed as well.
Fixes #967 for real
Ticket URL: <https://trac.osgeo.org/fdo/ticket/967#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
