[Fdo-trac] [fdo-trac] #893: MySQL Provider upgrade to use ST_INTERSECTS()
trac_fdo at osgeo.org
Sat Sep 28 15:20:52 PDT 2019
Reporter: kshippey | Owner: jng
Type: enhancement | Status: closed
Priority: major | Milestone: 3.8.0
Component: MySQL Provider | Version: 3.8.0
Severity: 3 | Resolution: fixed
Keywords: ST_INTERSECTS | External ID:
Comment (by jng):
In [changeset:"7858" 7858]:
#!CommitTicketReference repository="" revision="7858"
Merged revision(s) 7856 from trunk:
Implement the full suite of spatial operations for the MySQL FDO provider
if the MySQL version is >= 5.6
New capability tests have been added to verify the appropriate set of
supported operations is returned based on the MySQL version.
Fixes #893
This merge removes some C++11-isms which were present in the original
commit being merged from as 4.1 branch does not mandate the use of a
C++11-compiliant compiler like trunk does.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/893#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
