[Fdo-trac] [fdo-trac] #974: Creating a spatial context with a dot (.) in the name makes it un-destroyable
FDO trac_fdo at osgeo.org
Wed Jul 1 04:07:38 PDT 2020
destroyable
   Reporter:  jng                |      Owner:  danstoica
       Type:  defect             |     Status:  new
   Priority:  major              |  Milestone:
  Component:  SQLServer Spatial  |    Version:  4.1.0
   Severity:  3                  |   Keywords:
External ID:                     |
 If you create a spatial context in SQL Server whose name contains a dot
 (.) character, it cannot be destroyed later on through the equivalent FDO
 command.
 I suspect this is the same class of issues with this provider when dealing
 with objects with dots in their names (such as #930)
Ticket URL: <https://trac.osgeo.org/fdo/ticket/974>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
